05-29-2015 09:38 AM
Hi all
I have a flowmeter FTB-1302 and Nı USB 6229.I have connected them and read data as a square wave.How can i convert this square wave into real values.I mean i want to read flowmeter.
Here is my vi code and my squarewave graph.
Thank you
05-29-2015 09:43 AM - edited 05-29-2015 09:45 AM
You need to read the manual of your flowmeter and determine how the actual flow rate relates to the frequency of your signal. Most sensors make it a very easy linear relationship. Then just do the calculation and display your result in an numeric indicator. No need for a graph unless you like looking at a square wave. Although you might want to chart the numeric value so you have a history of the flow rate.
EDIT: There is a VI called "Extract Single Tone Information.vi" that can read the square wave and return its frequency. ![]()
05-29-2015 11:04 AM - edited 05-29-2015 11:05 AM
Actually i am new in this area could you please explain me which part of the manual i sould read exactly and at what considerations i sould be careful about?And you said about calculations.What kind of calculations and how?
Thank you
