05-16-2007 03:05 AM
05-16-2007 07:45 AM
Hello Marten,
I would doubt the problem is due to hardware. The specs you have given are ok enough (though not stellar). You should definitely not need 1minute to draw a wire!!
Another setting you could check is the video RAM / graphics card specs of your PC. If you do not have a card with dedicated VRAM, your graphics chip is sharing system RAM (of which you have 512MB). Somewhere in the BIOS there will be an option to set how much system RAM can be shared for video purposes. This is typically like 16MB to 128MB. Set this as high as you are allowed to.
If you still see the slow linedraw, I would conclude something wrong with either the LV installation or the windows installation or the graphics driver installation.
Is drawing the wire the only thing that appears slow?
Or are other LV functions also slow?
How about non-LV or non-NI programs, do they work fast?
05-16-2007 09:02 AM
05-17-2007 07:34 AM
