em 03-05-2009 07:50 PM
I am having a weird problem with long term sound input from a sound card using the Sound Input VIs. I am reading from 2 stereo inputs (so 4 cahnnels altogether). So I have 2 simultaneous data acquisition loops reading from two different devices (each device = 1 setero input). When I start the program everything runs just fine. But at unpredictible times over the course of the DAQ the inputs start to have big jumps in the signal. I am pretty sure that it is a software problem because when I stop and restart the program everything is fine. The jump are clearly not actual sound. Is there any known bug with the sound input VIs that could be causing this. Again since it happens at irregular intervals and immediately is fixed by restarting the program I don't know think its my code but rather a problem with the SondIn drivers.
I'm using LV 8.6.1 with a Marian Marc 8 Midi sound card.
em 03-05-2009 08:05 PM
em 03-05-2009 08:08 PM
em 03-05-2009 08:16 PM
em 03-05-2009 08:19 PM
i'm having issues because the sound control VI are somewhat different than NIDAQmx way of doing things.
could i ask you one more question?
i am also doing concurant sound output with the same card. That will use a seperate dll right? So are there any memory overlap issues there?
and there I have to do the soudn outputs seperately so I can not join those into one playback.
thanks
em 03-05-2009 08:48 PM
em 03-05-2009 08:58 PM
yeah i got that. i'm going to setup a simlified test program to run tonight that just reads from 2 channels seperately while playing sounds out as well to see if there is something else causing this problem in my code.
i do appreciate your help regardless though. if this is the probem then i won't be able to do my program with the sound card since output will be an issue.
i'll let you know.
thanks again!
em 03-06-2009 04:16 AM
em 03-06-2009 11:54 AM
em 03-06-2009 12:48 PM
evren wrote:
so right now my buffer size is 1sec (44100 samples) and I'm reading 30 ms (~1300 samples) at each iteration. so i thought that was high enough. i'll try going higher but I've found that buffer overruns cause an error and stop input completely - is there a miniumum overrun quantity to trigger an error and stop input?
I am not sure about the exact number. But I have observed something like you mentioned. If your program permits it you may also try to read more samples at each iteration (hence not so often as every 30ms) It may also help. I have evaluated a 24 bit sound card for medical data collection (soundcards are cheap). I have used update rates in range 50 to 100ms, and it seams to be working very stable. It was some problems then my buffer size was to low. But these problems are gone now
