Showing results forĀ
Search instead forĀ
Did you mean:Ā
simulating crane vi
I want to draw a vi in which a wheel  motion is translated into the linear motion.The wheel need to move on a single rail.the parameters given are radius on the wheel and the velocity with which it need to move on the rail.
i am having no idea how to implement this rail n wheel concept.please help me.
thanks in advance
(3,499 Views)
Some more details would be helpful.
Are you looking for a interactive graphical representation of wheel/rail on the front panel or do you only need the math behind it?
2 Inputs: wheel size and velocity.
What should the output be? (e.g. required wheel RPM)
(3,486 Views)
yes i am looking for a interactive graphical representation of wheel/rail on the front panel.rpm value u can take as any example value.
(3,451 Views)
Hey, your best bet is to use 3D picture controls.  I have seen a lot of cool animations with this and it now comes in LabVIEW 8.2 (anything above Base).  The link below will be a good starting point for how to use this.
https://www.ni.com/docs/en-US/bundle/labview/page/3d-picture-control-vis.html
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(3,434 Views)
