silver style array
I kind of like the new silver style but I do not like the new array style.
For instance here is the default layout for a 1D DBL array:
What is that void around the numeric control? It looks like it is floating above the array object...
Wouldn't have been easy to use a style similar to the matrix object? (but limited to 1D):
(4,020 Views)
Accepted by topic author X.
There is also a frameless numeric control, which is much better for using inside an array.  In fact there is also a Numeric Array in the array controls which has this already set.
(4,002 Views)
Correct, but I guess I meant that this is a general issue. Example:
Things tend to "float" above the underlying ones, and there is no way to get rid of these annoying gaps to the right and at the bottom (AFAIK)...
(3,995 Views)
I am adding this remark, which belongs to the gray area between a stylistic feature and a design bug:
There is a 2-PIXEL SHIFT between the index display and the silver style array frame:
Of course, this is easily corrected by Edit>> Customize Control and shifting the index:
but why do we have to do that?
(3,827 Views)
