[HELP] problem with receiving data through rs232
    When I connect my VI with MCU (using proteus to simulate), why does it run stable in only 20 seconds? After that, it seem to be unstable. And when I stop simulation in proteus, why does my VI still run and stop after about more than 10 seconds?
   thanks!
Message 1 of 17
(5,431 Views)
What do you mean by "run stable" and "unstable"?
Give some specific details on how your VI is not working properly.  Do you get any error messages?
Message 2 of 17
(5,428 Views)
thank you for reply!
there is no error message. in first 20 seconds, values in array are the same. u can see the image in anh.zip (426 and 426), but in the unstable status, they are different. can u open the code in uart.zip? those values are always the same.
Message 3 of 17
(5,423 Views)
can anyone help me?
Message 4 of 17
(5,388 Views)
I am not sure which file you are refering to in your zip file that is always staying the same, seeing as how there are a great deal of files in that folder.  Is the VI you included example code from somewhere, or something that you wrote?  I am not sure that I understand this unstable behavior you are describing.  Your VI appears to be simply reading data off the serial port, doing some processing on it and then modifying your images.  One thing I noticed is that you are configuring the serial port with each iteration of you loop, that should not be necessary.  I don't know if that has something to do with the problem, but still.  I saw that there is an array output on your VI, is that the array that is showing you stable data for 20 seconds, and then unstable afterwards?
Shane C
Message 5 of 17
(5,354 Views)
please check this video.
https://www.dropbox.com/s/esbfl8mck5pdyw3/IMG_1343.mp4
it is unstable after forty seconds.
thanks for reply!
Message 6 of 17
(5,341 Views)
How fast is your device sending data?
How are you reading data?  (I can't open your VI because it was saved as LV2013)?
Try putting some error indicators on the error wire coming out of your VISA functions.
Seeing the video and seeing how fast data is flying in, I'm suspecting that your device is sending data faster than you are reading it in LabVIEW, you are filling up the buffer, and thus losing bytes.  If you disable the part of your code that generates the picture, does it seem to run any better?
Put in a "Bytes at Port" property node and put an indicator on that to see if the number is staying consistently low, or if it is continually growing.
Message 7 of 17
(5,324 Views)
Reading and sending speed are 9600. you are right, the buffer was filled up, but I don't know the reasons. If I read 22 bytes in Labview, it will run stable for 20s, when I decrease the byte count, the stable time increase. If sending and reading speed are the same, why is the buffer filled up?
When I stop simulation in Proteus, it still run for several seconds before stop (I think, it run by the data in the buffer). But, if I connect with PL2303 module then disconnect, it will stop immediately.
Message 8 of 17
(5,311 Views)
May I ask your experience with instrument communications?  With LabVIEW?  We can probably give better advice if we knew.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 17
(5,298 Views)
It sure would be easier to read your pictures if your wires were somewhat straighter, didn't go backwards, didn't run under other wires or structures, appear to enter subVIs at the wrong terminal, or just appear or disappear at the edges of structures.
If your program stops after approximately 53,000 bytes (422,000 bits) no matter how many you read in a chunk, then I'd look at the sending end rather than the receiving end. But I don't have LV 2013, as many of us don't yet, to look at the VIs you sent in the first message.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 10 of 17
(5,288 Views)
