signal generation
how can i generate a square pulse of desired width and delay in labview?
Message 1 of 12
(4,153 Views)
Look at the Signal Processing palette. There are VIs which generate arrays with square waves or pulses and othes for waveforms.
Lynn
Message 2 of 12
(4,140 Views)
...and once you have the waveform, are you wanting to output it from the computer in some way?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 12
(4,118 Views)
yes, i do want that.
Message 4 of 12
(4,105 Views)
What hardware are you planning to use?
Mike...
LabVIEW Champion
Message 5 of 12
(4,101 Views)
Mike,
Do you think we qualify for dental licenses after all the teeth pulling we do to get to the real questions?
Lynn
Message 6 of 12
(4,077 Views)
Mike...
LabVIEW Champion
Message 7 of 12
(4,067 Views)
I m using SCB-68A as the interface device, and i have to trigger an injector for a given period of crank angle, that's why need to know how to get a square pulse of given delay and width.
Message 8 of 12
(4,048 Views)
Please provide the actual DAQ device you are using. The SCB-68 is a dumb terminal block as you should know.
Message 9 of 12
(4,038 Views)
it's NI PCIE-6361 X SERIES DAQ.
Message 10 of 12
(4,033 Views)
