shifting array's index down
I am trying to get my array to shift its index down so that everytime i submit an employee it will be added to a different index such as a[0] is submitted and than when i go to add another employee it will shift to a[1].
here is my code
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 1 of 22
(5,208 Views)
Accepted by Harold_Timmis
It's really simple if you understand one of the basic functions in LabVIEW - the shift register. With this and a Build Array, there is not much to the code. Here's an example. I also used an event structure. You would need to modify it so that when the submit is clicked, the values in the cluster are cleared.
Message 2 of 22
(5,196 Views)
I dont want values to be cleared I want to add employees to the list an update list so when i add an employee does not replace an employee already in the system.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 3 of 22
(5,170 Views)
That is exactly what the provided example will do for you.  Have you tried it yet?
Message 4 of 22
(5,167 Views)
Please mark Dennis' message as the solution to your answer.  You marked your own message where you doubted his correct solution.  You will need to use the Options menu to the upper right of your message to unmark you reply as the solution.
Message 5 of 22
(5,156 Views)
I can't open this file because i am using 8.2 right now
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 22
(5,116 Views)
Sorry. Here's a version in 8.0.
Message 7 of 22
(5,112 Views)
This worked great but when I submitted my product I would lose the employee's I have entered and vise versa, so I modified it to where that wouldn't happen; here is the code I used:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 22
(5,098 Views)
thank you dennis for helping me out
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 22
(5,097 Views)
for what ever reason the code I created worked for a while now it does not? it will not let me enter any new objects and when i try to enter in more objects my program freezes to where i have to abort the program I can't figure out why??
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 10 of 22
(5,089 Views)
