vertical scroll bar multi array
I am trying to get a scroll bar to work with two arrays so that both arrays move at the same time when the scroll bar is used.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 1 of 13
(5,466 Views)
Accepted by topic author Harold_Timmis
I figured it out here is what i used:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 2 of 13
(5,449 Views)
Your signature indicates that you are doing commercial work but your VI image indicates you are using the student edition. That would violate the terms and conditions of the student edition.
Message 3 of 13
(5,407 Views)
thank you for noticing I use it for tests when i am home, but at work i actually have the full application.
so no I am not violating any rules
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 13
(5,398 Views)
The LabVIEW license allows you to install it at home.
Message 5 of 13
(5,379 Views)
it is not my software it is the companies software
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 13
(5,360 Views)
So?
The license agreement for a named user says that you can install it on 3 business computers at one time and may additionally install it on one home computer.
Message 7 of 13
(5,351 Views)
Thank you for that information I will consult my manager to see if I may install it on my home computer that is good news.
Thank you,
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 13
(5,339 Views)
There are a lot of gray areas with licensing, and both sides have a valid argument. One Dennis' side, you can normally install your LV on 3 computers for ONE user, or one computer for THREE users.
On Harold's side, if you are sharing the computer with other people or "this copy" of LabVIEW has already been installed elsewhere or on a home computer, than you should not install the same serial number on your home computer.
But if you know that you are the only user with this serial number, and don't have any dominant contracts with your company saying that you can't use your LabVIEW at home (this happens a lot more than you would think)  than you would be fine installing it at home.
Chris Van Horn
Message 9 of 13
(5,335 Views)
which is why i said i will talk to my manager about it because it is his copy
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 10 of 13
(5,331 Views)
