setting DPI of image
I am trying to create an image and then save that to a file to be printed later. I notice that the picture functions seem to default to a 96 DPI image. Is there some way to increase that? I need to add some pretty small text to the picture and it is turning out eligible.
(3,997 Views)
I'm not sure that you have any control over that. BTW: What does your text turn out to be eligible for? 🙂
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,970 Views)
Tackle eligible?  Or is it a Patriots stunt where you declare a running back ineligible?
(3,962 Views)
Accepted by Muffin
If you save to BMP, you can specify pixel per inch in horizontal & verticle.
You have to modify the Write BMP File.vi a little bit, so that you can pass the header in, and not get overwrited.
George Zou
(3,942 Views)
I had just figured this out actually.  This works great.  Not sure why it doesn't come like this.
(3,919 Views)
Could you please provide the solution?
(2,878 Views)
