selected with rectangular
Most of the issue seems to center around the array subset VI (mouse up event).  It looks like the inputs are index (0), length(0), index(1), length(1) but you are passing in rectangle coordinates (x1, y1, x2, y2).  Another possible problem is the Y scales on the graphs.  The mouse coords start upper left corner but graph is scaled reverse in the Y axis.
Message 11 of 14
(862 Views)
Hi Todd
Can you please send me this cod , I write this code and it have some problem maybe I make misteke in some things because I do not know about another page of Event structure.
Best regards
Message 12 of 14
(856 Views)
The image has code in it. Save the image as a file, then drag the file onto a LabVIEW block diagram. It's called a Snippet.
Message 13 of 14
(854 Views)
Thanks so much Todd
I use this in my code and it works very well.
Message 14 of 14
(839 Views)
