modbus tcp/ip write.
I've got an iologik e2240 Moxa device and I'm using a Modbus protocol via TCP/IP to communicate with it. Using the NI Modbus Library, I have no problem with reading coils and registers but when it comes to writing any data to device, the MB_Ethernet_Master_Query.vi is returning an exception code 6 ( Busy, rejected message).
I got to know what Modbus is yesterday so I am a complete newbie.
Does anybody know why this exception occurs ?
(5,126 Views)
06/0x06 Busy, Rejected Message Specialized use in conjunction with programming commands.
The server (of slave) is engaged in processing a long-duration
program command. The client (or master) should retransmit
the message later when the server (or slave) is free.
(5,108 Views)
I've founded explenation to this excepton code, but I didn't know why writing to registers caused this exception.
Finally after few hours of trying everything I've figured out that although some registers in this device are marked as a read/write, you can only read them (attempt to write them causes exception code "6").
(5,106 Views)
Yeah, I think that what happened to me in the past as well.  That's why I only read/write holding registers.
(5,104 Views)
This happens also with holding registers on this device I'm using.
(5,102 Views)
