select multiple files and folders
Here's a VI that will let you mess with all 32 selection mode flags.  (Only 4294967295 combintions ti try!).
WARNING!  THIS MAY CAUSE LV TO CRASH.
Message 11 of 16
(2,321 Views)
Any hint at to the purpose of various selection mode flags?
Message 12 of 16
(1,847 Views)
I updated it so it includes the entire path
Message 13 of 16
(1,538 Views)
There is a chance it's simply passed to the MS OpenFileName function directly.
If so, the flag section here would describe it.
Message 14 of 16
(1,528 Views)
I doubt that. The File Dialog is used on all LabVIEW platforms and its internal API is pretty much decoupled from the actual platform API (with the exception of the pattern input which you can pretty much massage into the double NULL terminated string that the Windows API expects to see for multiple patterns, but which won't work properly on non-Windows platforms).
Rolf Kalbermatter  My Blog
Message 15 of 16
(1,519 Views)
Makes sense.
Message 16 of 16
(1,507 Views)
