search and replace
Bonjour,
Mon Labview 8.0 fait des siennes, j'ignore pourquoi mais lorsque je place un string constant devant certaines boites "search and replace" (cherhe et replace) il me sort le string d'entrée + tout ce qui se trouve après le string recherché. Donc je me retrouve avec deux fois le string d'entrée dans certains cas.
J'ai déja redémarrer mon ordinateur sans succés.
merci d'avance.
joël
"We are the knight who said "NI" !"
Monthy Python, sacré graal
Message 1 of 10
(4,038 Views)
Pouvez-vous attacher le VI qui montre la recherche que vous essayez de faire ?  Nous laisser en outre savent ce que revenir vous comptez.
Google utilisé pour traduire si désolé pour toutes erreurs.
Message 2 of 10
(4,028 Views)
Sorry, i didnt see where i post.
I have a problem with the "search an replace" box in Labvoew 8.0. I don't know why but when i give it a constant input string, it return me the input string with the all after the research string. Sometimes i have twice string. What can i make ?
I have reboot my computer.
thanks for reply.
joël
Message 3 of 10
(4,024 Views)
This my programm
Message 4 of 10
(4,022 Views)
This my program
Message 5 of 10
(4,020 Views)
I ran your program and it seems to work fine to me.  Which part is not replacing like you expect?  From your post it seems like sometimes you get the entire string again?  Have you found a consistent set of values that produces the behavior?
Sorry I don't have a better answer yet.
Message 6 of 10
(4,009 Views)
I don't see anything wrong with your code, but I suspect that you accidentally enter multiple lines into the text boxes.
You should right-click on all the small string controls and select "limit to single line". See if this helps!
Message 7 of 10
(4,008 Views)
Hi JO 61,
Re: your signature.
See this thread
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=79&jump=true
Ben
Message 8 of 10
(3,993 Views)
Are you searching for strings whic contain reserved characters? *?^/ and some others are used for special purposes. Look at the Context Help for more information about these characters. I was searching for "???@???" today and had the same results you report. Changing the search string to "/?/?/?@/?/?/?" got what I wanted. (It might be \ rather than /).
Lynn
Message 9 of 10
(3,976 Views)
Thanks you very much for all this reply !
I don't know why, but this morning, when i run my program there was nothing wrong, and i don't change something. I suppose it was my computer.
thanks you again.
Message 10 of 10
(3,964 Views)
