Html file in application builder
Hi.  I am using NI to generate a report that in html format.  It functions fine with runing vi files.  But when I build a application with .exe extention.  It dose not save the file or open the URL window any more.  Do I need change any settings in build the application.
Jennifer
(2,546 Views)
Jennifer
I assume you are using a version prior to 8.0 since you talk about Application Builder. Go into the Installer tab, select the Advanced button and in there make sure the "LabVIEW Run-Time Engine" and the "NI Reports Support" are checked. Then use the created installer to install the applciation on your target computer.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,541 Views)
