script error in measurement & automation explorer
Hi, I have tried to configurate cRIO 9012 using MAX but always obtain a script error and I can't work with my device.
I hope you can help me, there is a print screen.
(2,821 Views)
It looks like you did not setup your IP address. Try setting up your IP address on the cRIO in the devices. Right now it show as 0.0.0.0
Tim
GHSP
(2,815 Views)
Hi!
Which version of MAX are you using?
Is this the first time you try to configure a cRIO controller in that machine?
Here's a link with a quick guide on how to set up a cRIO controller in MAX:
http://digital.ni.com/manuals.nsf/websearch/C9721DD0A5F989CE8625760A007D4D1B
Regards!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(2,805 Views)
