03-23-2008 12:37 AM
03-24-2008 10:39 AM
03-24-2008 12:43 PM
03-24-2008 12:58 PM
03-25-2008 12:05 PM
03-25-2008 12:12 PM
04-01-2008 03:09 PM
Lynn,
I have done what you suggested. Nevertheless, I have another problem. I am using 16 analog input channels in my scb68 and I would like to run the acquisition for 2 minutes. I am taking 500 samples at a 10kS/sec rate. I used a for loop 2400 times (2400=120sec/.05sec) but it takes more than 2 minutes. I tried different times for the time loop and i found that it takes around .065 sec each iteration. I think it is because i have a high input impedance, for the time it consumes to process some vi i have inside the for loop or another cause. Do you have any idea?. Finally, it is important to state that the time seems constant, that means, the 2 minutes are constant.
thanks
miguel
04-01-2008 03:19 PM
04-02-2008 04:35 PM
04-03-2008 10:42 AM
