Array scroll bar is missing
I have an array of clusters that I want to switch from an index to a scrollbar display. It seems that the scroll bar is missing in the display. I am using labview 8.2.1
I have attached the VI.
Message 1 of 9
(4,639 Views)
Hi Joseph,
which one did you mean? Here is a scrollbar.
Mike
Message 2 of 9
(4,635 Views)
I should have placed a picture to show where the scroll bar is missing. It is the outer most item.
Message 3 of 9
(4,622 Views)
Very strange. The scrollbars are actually there, and can be seen if you go into the control editor. Somehow they've been shoved off to display underneath the cluster. Do you remember the order of steps you did to create the control? Did you customize the control at any point?
Message 4 of 9
(4,607 Views)
Here is it ! It guess that it has been moved under the cluster while customizing the control.
Message 5 of 9
(4,599 Views)
Orignially they were just built up from scratch and then I started to convert them to type def. At that time, I had the standard index. I thought it would lead to a better view using scroll bars. This then appeared. I just remove the type def links and presented the control.
I do not remember making any special editing.
Message 6 of 9
(4,596 Views)
Unfortunately, I can not open the VI, it is 8.5 and I am using 8.2.1. If it was under the cluster, why is there a blank space for the area? or is it because a different behavior under 8.5?
Message 7 of 9
(4,594 Views)
The restored control in LV8.2.
Message 8 of 9
(4,588 Views)
I will be fixing my things with it.
Message 9 of 9
(4,582 Views)
