scan tolken string
OK I have been working with LabVIEW for many years and I have never understood the Scan strings for Tolkens.
Attached is what I expect, and what I am getting.  Please set me strait once and for all.
Dan
Dan Shangraw, P.E.
Message 1 of 15
(6,497 Views)
Would help if I posted a VI that illustrates my problem.
Late night and I am woozy from beating my head against the wall.
Dan Shangraw, P.E.
Message 2 of 15
(6,493 Views)
Your input string control is empty.  Try saving your VI again and posting it after putting some data in the input string and saving it as default.
Never mind, you reposted the VI.
Message Edited by Ravens Fan on 08-11-2009 11:11 PM
Message 3 of 15
(6,492 Views)
I've never used scan token string before.  Looking at the Context help and examples for it, it looks like it is meant to break up a string by the tokens, and is most useful if it is in a loop.  In your case, you are trying to find a string "wrapped" in your token.
I would use Search/Split string or Match Pattern to find the quotes and strip them out from there.
Message Edited by Ravens Fan on 08-11-2009 11:30 PM
Message 4 of 15
(6,485 Views)
I couldn't open the VI (still waiting for upgrade), but I did use the Scan String for Tokens in an example recently.  I have found it to be quite useful when I have a complex string to parse, with unknown or varying number of parameters.  I find that strings with regular patterns are more efficiently dealt with using string to spreadsheet array or scan string to number.
Reading Ravens Fan's post, I gather you are looking for values inside quotes, I have enclosed an example which pulls numbers out of a quoted, comma separated list.  The quotes are delimiters and tokens are the values you are looking for.  Hope this helps.
Message 5 of 15
(6,469 Views)
Oops, posted old version, here is the corrected vi with initialized SR in while loop.
Message 6 of 15
(6,466 Views)
I'm getting something different...
Jim
Message 7 of 15
(6,440 Views)
Accepted by ASTDan
First of all, you're looking for the output from the wrong place.  "String out" is an unmodified copy of the input string.
"Token out" is the response you're looking for.
The first iteration will find your starting " as adelimiter and deliver the part of the string up to but not including the " character.  The second time you call the function (wiring through the returned index from the first run) it will give you the text between the first and second " which is exactly what you're looking for.
Shane.
PS My first Snippet! 😄
Message 8 of 15
(6,434 Views)
Just in case you expect more than 1 string between tokens 🙂
No one asked for it, yet, but who knows what tomorrow brings Smiley Very Happy
Message 9 of 15
(6,425 Views)
Wow!  Thats how that works!  I was just inputing quotation marks.Smiley Happy
I am going to haning out with Tom Bombadil now.
Dan Shangraw, P.E.
Message 10 of 15
(6,421 Views)
