scan string problem
Hi everyone!
I am relatively new to labview programming and have got stuck to resolve to the follwing issue.
I have got a an alarm panel, which has a default output in the following format (in case of no alarm)
$IIARL,,000,V,A,*38 [default value]
The 000 porion shows the address of the alarm and the last two digits represent a particular code, so I am only interested in these two values.
I tried the follwing string format to scan only the requisite paramters.
$IIARL,,%3d,V,A,*%2d
match characters ($IIARL,,) ----- scan 3 places of decimal value (%3d) ----- match characters (,V,A,*) ----- scan 2 posiitons of decimal values (%2d)
After running the VI, I got the following values
adress = 0
code = 38
remaining string value = empty
This is nice and accpetable.
But when an alarm event occurs the address and code changes to lets suppose 000 > 013 and 38 > 84.
In this case output becomes
adress = 13
code = 0
remianing string value = V,A,*84
where, ideally I am looking for the following results
adress = 13 or 013
code = 84
Best Regards
Shabbir
(4,536 Views)
It would help to debug if you attached your VI with your test cases.  That way we can see if there's a problem with the way things are being wired or if there's something more to it than just that.
(4,532 Views)
Use %d instead of %3d and %2d.  This way you can have any number of characters for the address.
Also, am I seeing that a comma is missing in the error message (right after the address)?  Or was that a typo?
(4,505 Views)
I would recommend to use "spreadsheet string to array", with the comma as separator. Then you can acces the fields via array index.
Greets, Dave
(4,497 Views)
I did exactly what you say you did, and got the expected answers of 13, 84, and an empty Remaining String.
(4,476 Views)
@crossrulz, I think, I have tried this randomly but don't excatly remember the results
(4,450 Views)
@daveTW
will defintely give it a try tomorrow morning and will reprt back here
(4,445 Views)
