in data 04-08-2006 02:31 AM
Hiii,
Mr. Bhatti, i got your problem.... , so i am requesting you to send a file in which you have store the data, from wrtie to spreadsheet file, so that i can modify the vi for the read, it is required to be formatted at the inouts which are coming at the string formation, so that it reads the perfect string which is stored in the data, please send me the file.
Nishant
in data 04-10-2006 09:26 AM
in data 04-10-2006 11:01 PM
Hiii,
Actually these stored data are not in perfrct method, so can you please send me ur vis, so that i can modify them to store? and please use the excel files to store the data (however it doesnt matter but still its a good practice rather than txt file), i will modify ur vi to store the data in perfect method and whenever you post vi or any other files please send it in the zip file, so that file size can be decreased cos i have the limitations to downaload the files. plese send me files with all the drivers included inside so that it shouldnt be the question of not opening vi, which delays ur project, cos i have suffer this ways in my project, which costs me more days for completing the project.
Nishant
in data 04-11-2006 03:28 AM
in data 04-12-2006 08:41 AM
in data 04-13-2006 06:02 AM
Hiii, Mr. Bhatti
Sorry to replying you late, but i was somewat busy in my work actually. I think the data coming into the file is not properly formatted while writing the data, and i am sorry to say but i dont have the LabVIEW 8th version, because i forcefully told you to send it, but you can do one thing, can save in 7.0 or 7.1 version, while doing save as, there is an option of "save with options" on the file menu, in that there is an option to save with the previous method, so there you can save this vi with 7.1 version or 7.0 version, so that you can send me that version which is cocmfortable for me to change, i will format that file for sure to write the correct data.
I habent analyse your data properly so that i can tell you, what is the basic problem in writing the data, but once i ll analyse i will mail you.
One another thing i like to say is, as in the last post you send me the data.xls.csv file, which is not a proper method to write, there should either be .xls extension or should be .csv extension. one is the excel file and another is comma seperated value file, and the comma seperated will be tab delimited file in which we will sotre the data, it will show as an .xls but htat is actually be the csv file.
Nishant
in data 04-14-2006 05:57 AM
in data 04-16-2006 01:49 PM
in data 04-16-2006 11:11 PM
Hii, Mr. Bhatti
I dont know why you are saving the file in the .dat file, when in i tried to open that file with the option open with, the message was ,this kind of files are used by OS and it could be dangerous yo modufy, so i prefer you not to ie this kind of files.
Another thing is yes, you cna oprn four different files for writtening four different files, and for that you use same method for file writing by using four open, write and close express vis.
Nishant
