using charts
hi, im wantig to chart changes in amplitude of a given aquistion. i need the start time and date to remain in bottom left of chart. im finding it difficuilt to achive this! ive had a look at the xy chart and its basiclly exactly what i need if only the min value would stay static, i.e one fixed time. the way i need it to work is kinda like how it defualts when you us a single chart vi, and select absoolute time. execpt not with the silly time format.  whats with thtat 1904 thing anyway. i neeed current realistic dates and time . and also there is a delay between loging points on the chart (3 seconds) however, when its marks the next point, it increments th seconds by only 2 second!
hope you can help.
thanks.
(2,818 Views)
To get realistic dates and times, just set the offset to the current time and the correct increment/point at the start of the program. (See LabVIEW 7.0 example).
(Another possibility would be to work with waveform data).
(2,808 Views)
