save the selected value from listbox with its respective tab control dropdown selcted values in another listbox
Hi all,
I am making a vi where I have to save the selected value from listbox with its respective tab control dropdown selcted values in another listbox.Whenever I select Item1 then the heading change and respective tab will open for that item.But Now I just want to save the selection and put it in another ListBox.SO that I can renmove or add according to my wish. Plz help me.
Message 1 of 14
(5,115 Views)
You can better upload your vi.
Then people are able to see how far you've coded it.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 2 of 14
(5,094 Views)
Hi rita86
To copy from one listbox to another use the Item Names property as shown ....
Message 3 of 14
(5,075 Views)
Thanks a lot sir, actually I want this operation to be performed only after clicking on add configuration button.Then only selected item should come in output listbox.
Message 4 of 14
(5,069 Views)
Then use an event structure to perform the transfer from one listbox to the other when you click the add config button. Smiley Wink
Message 5 of 14
(5,064 Views)
Thanks sir for your quick response, but according to this vi , whenever we select like 1 from listbox 1 then whole numbers in the listbox2 come like 1 to 5.I want to code in such a way so that when I select 1 from listbox 1 then on clicking ok, it should display that selected value in listbox2., it should not show other values.
Message 6 of 14
(5,049 Views)
Hi, I successfully make the vi to insert itmes from listbox1 to listbox2.Whenever I select itmes 1 in listbox 1 it display same elected item in listbox2 , but it not appending the items in listbox2.Like If 1 is selected in listbox1 then 1 will display , next time after saving when I selct next item like 3 then in listbox 2, 1 is replaced by 3,it dont come in second row of listbox2.Hope I am able to explain.\
Plz help me to resolve this.
Message 7 of 14
(5,017 Views)
Accepted by rita86
This will work.
Probably not the greatest solution though.
Message 8 of 14
(5,007 Views)
Hello sir,
I am applying this logic to my vi but its not working.It want listbox1 values should be displaye in sensor output listbox .
It should take selected values from list box and its respective tab selected in listbox2(Sensor output).After applying this logic its not working.Plz help.
Message 9 of 14
(4,991 Views)
Do you mean that if you select 'NI Node 3202' in listbox 1 you want listbox 2 to display 'NI Node 3202'
as in the attached VI ...
or do you want all of the information ... AI7,AI6,AI5 etc etc on the tab page to be displayed in listbox 2 ?
If so how do you want it displayed ? what order ? which values ?
Message 10 of 14
(4,983 Views)
