12-04-2006 07:36 AM
12-04-2006 10:49 AM
12-05-2006 01:10 AM
Thank you, GerdW.
12-05-2006 02:13 AM
I'm sorry I disturb you, but I'm trying to use Binary File VIs and I cannot use it. I've created an array with all my messages but I cannot wired to fuction (write to SGL or write to I16). It's because my array is string, no data.
Vicens
LV7.1 / WinXP
12-05-2006 02:43 AM
12-05-2006 02:50 AM
12-05-2006 03:21 AM
12-05-2006
08:10 AM
- last edited on
11-01-2026
11:23 AM
by
Content Cleaner
Actually, the limit for LV7.1 is "normally" 2GBytes, since LV7.1 uses 32bit signed pointers for file access. However, there is an easy way around this in WinXP, provided your file system is NTFS, not FAT32 (it is, isn't it
). You can find complete directions and code examples in the tutorial Managing Large Data Sets in LabVIEW. Click on chapter 5 in the table of contents to take you to it. Note that the HDF5 utilities mentioned in that tutorial make an excellent binary file storage mechanism, although the learning curve is more than a bit steep.
