same device multiple channel acqusition at different sample rate
Hi
I want to acquire signal from NI 9219 from two (or more) channel simoultaneously, at different sample rate for each channel.
Meaning
Channel 1: sample rate = 1kHz
Channel 2 sample rate = 100kHz
Channel 3  samplr rate = 50 kHz
all to be acquired simoutaneously.
Please help
Thnx
Ravinder
(3,638 Views)
You can have a timed while loop at 100KHz (if your hardware supports it).
At each iteration read the 100KHz channel,
every 2 iterations read the 50KHz,
every 100 iterations read the 1KHz.
This may help
(3,633 Views)
...or if you are not running on a cRIO device, read all channels at 100K and then just toss all of the "extra" data. Smiley Wink
Ben
(3,626 Views)
Don't toss the extra data.  Use it. Smiley Tongue You can average for better noise immunity and higher resolution.  You can get max/min/stdev.  There are lots of options...
Of course, you could just toss it. Smiley Very Happy
Message Edited by DFGray on 06-20-2008 07:50 AM
(3,594 Views)
DF wrote;
Don't toss the extra data.  ...
(3,588 Views)
Haha, that was funny!
I agree with all those posts above. If you don't have a cRIO, those are two good options.
PBear
NI RF
(3,570 Views)
The 9219 can handle simultaneous input upto 100 S/s/channel, meaning 100 Hz, which is not in the kHz range that you wanted.
Message Edited by FieldKam on 06-20-2008 01:20 PM
Kameralina
(3,554 Views)
