running 2 vis in parallel and returning parameters to the caller
I looked at your example and appreciate the feedback.  However, that's not the approach I was looking for.  When I'm finished, I will have about 40 different "child" VIs each with many controls.  The reason I was trying to put the controls for each function in different VIs was to keep the code in the main VI as small as possible.  So I was trying to let each child VI accept user input and pass back to the caller one double with all the data packed into it.  These doubles are then going to be fed into another application written in MatrixX.
Message 11 of 16
(1,022 Views)
Understand.
IMHO the problem is, that you use an array of buttons.
Try to use single buttons and bundle these to an array. If I remember right, then LATCH doesnt work for an array of buttons.
Balze
Message 12 of 16
(1,019 Views)
IMHO?
Message 13 of 16
(1,015 Views)
sorry 🙂 In My Humble Opinion
Message 14 of 16
(1,011 Views)
Thanks for your quick responses!!
Message 15 of 16
(1,005 Views)
The links look like a great place to start.  Now I just have to find the time to go through them.
Message 16 of 16
(997 Views)
