Pass Events from main vi to sub vis in sequence
I'm new to Labview and im using Labview 7.1. I have a problem in passing events from main VI to sub VIs in sequence. I have a requirement where in if I press a button in main window, I want the event to be passed to subv VIs in sequence. Say if I press START button in main VI, I want sub VI 1 to be executed first, followed by sub VI 2 using the same event passed from main. Currently I'm able to achieve this by pressing the button twice. One for first sub VI and another for second VI. I have attached vi for my requirement, modifying the one which was available in the forum for passing events from main to sub.  Could you help me out where I went wrong / if this is possible?
Hema
(3,017 Views)
Hi Hema,
why do you want to register events in those subvi's?
Just run the subvi's when the user presses the button...
Message Edited by GerdW on 01-25-2007 02:53 PM
(3,005 Views)
Hi GerdW,
Thanks for your reply. Probably I wasnt clear. My intention is when I press Button ON/OFF in main VI, it should turn on button in the sub VI 1 first, followed by sub VI 2. I'm using Flat sequence to set the priority for sub VI 1 and then sub VI 2. If we do not Register events or pass by Refnum, sub VIs do not know event has occurred. From your reply I understand that sub VIs will run sequentially but will not run based on event in main.
Hema
(2,996 Views)
Hi Hema,
they run based on event in main vi! In my opinion you don't need additional buttons in the sub-vi.
You should maybe redesign your project. IMHO a subvi shouldn't wait for an event of the main vi. Subvi's should do some work and exit on its own after work. When a subvi needs a stop signal I usually use an global variable which is set in the main vi and only polled in the subvi.
To make my idea more clear:
Put the event structure in your main vi. Check for "button change"-event. When user presses button you just call sub1 followed by sub2 (you can do this inside the event structure).
See attachment - some changes are made. BUT: I would not recommend such programming!
For processing order of your subvi's you can use the flat sequence - it's ok. It would be much better if you would use some sort of data dependency - easiest is to use an error cluster in/out in every subvi. Please read the manual on this topic!
(2,989 Views)
Hi GerdW,
Thanks for your reply. It was very useful. Thanks for your time.
Hema
(2,977 Views)
