07-09-2013 01:18 AM
Hi everybody
How do we uninstall run time engine 2011?
07-09-2013 01:36 AM
Assuming you are running windows, go to the "uninstall a program" entry in the control panel and select the entry "National Instruments Software". Double-click it, select the desired National instruments software products and select "remove".
07-09-2013 02:02 AM
Can you indicate the product name of the run time engine.
07-09-2013 02:11 AM
Well, look for an entry that has the words "run", "time", "engine" and "2011" in it. Are you sure it is even installed?
(Is your question in any way related with the topic of this already solved thread? Please explain. I don't quite get it)
07-09-2013 02:28 AM
I can't find it in the product list. Please see attachment.
07-09-2013 02:45 AM
In fact it is showing missing plugin when I am running the runtime engine. But when I am trying to install it again it is showing that a later version of this product is already installed. I guess I have to uninstall it but I can't find the file in National Instruments.
07-09-2013 11:18 AM
What exact version are you trying to install? HOw big is the file? You already have full LabVIEW 2011 installed, so why do you need the runtime engone?
All major versions of the runtime egine can be installed in parallel. Could it be that you should try installing e.g. a SP1 version?
How are you "running" the run time engine? Typically one runs an application that uses the run time engine.
Can you show is an image of the error message?
07-10-2013 01:19 AM
I have attached the messages displayed when I am requesting to connect (plugin). Clicking on plugin opens the NI site. I have tried to update the run time engine with LRTE2011min.exe. The message shown is as attached.
07-10-2013 08:51 AM
Try opening your webpage in Internet Explorer instead of Firefox. Maybe the "plugin" problem is related to Firefox and not LabVIEW.
07-11-2013 05:53 AM
With internet explorer it is showing
