run once when click on button
Hello!
I have a question that is probably very obvious but I cant think of a good way to do it:
I want to have a LV-programme running continously and perform a measurement every time someone clicks a button. Then it should be idle and wait for the next mouse click to perform the same thing.
Mathias
Message 1 of 15
(5,042 Views)
I think the best and most simple way is to use a 'case structure'.
Andries
Message 2 of 15
(5,030 Views)
Thanks for your reply Andries,
I was going for the case structure, but I ran in to problems when it came to turning the logic off after doing a measurement so that it does not keep measuring several times.
So how would one turn the case into false after measuring?
I attach my VI so you can see the case structure I have right now with a start button.
Message 3 of 15
(5,024 Views)
Hi!
You can use Local Variable on RT or Property Node/Local Variable on Host.
Have a nice day!
Message 4 of 15
(5,020 Views)
Using Event Structure is the way to go!    See here and here to start using events
Message 5 of 15
(5,020 Views)
Look at attached vi
Message 6 of 15
(5,016 Views)
That looks very handy, I only have the basic package of LV unfortunately, so I am not sure I can use the event structure in a proper way.
I will see if I can use yours  Smiley Wink
Message Edited by Mathias_P on 05-28-2007 04:36 AM
Message 7 of 15
(5,014 Views)
If you can not use event structures...
try this the vi I attached.
Its with a case structure. The record button is modified (in properties).
Andries
Message 8 of 15
(5,006 Views)
I got it to work with the event structure, thanks for the suggestions
Message Edited by Mathias_P on 05-28-2007 05:47 AM
Message 9 of 15
(4,998 Views)
Note: Events would be a better option since you mentioned an 'idle state' for your vi
Connecting '-1' ( default) to timeout terminal, shall make your vi wait for an event and your while loop shall not iterate during absence of event
Message 10 of 15
(4,990 Views)
