Plot array
Is there a way to plot an array of 255 values.. The values 1,3,5,7,9 etc. are value's for the amplitude and the values 2,4,6,8 etc are values for the time... (x-axis)
(3,761 Views)
Hi marten,
what about using 'decimate array' to separate your x- and y-data?
Message Edited by GerdW on 05-25-2007 03:08 PM
(3,754 Views)
Thanks for the fast reply,
It works ok! Smiley Happy Thank you
(3,749 Views)
Is there also a way to plot:
x - value ; 1,4,7, 9, 12,15 (index of array)
y-value (bit 7-15)  ; 2,5,8,10,13,16
y-value (bit 0-7)    ; 3,6,9,11,14,17
The y value must been combined....
(3,683 Views)
Hi marten,
have you read the manual - or atleast the context help? Please do so!
I took U16 datatype as your y-data only (seem to) have 16 bits of information - change as needed. Also the filtering (Q/R and AND-operation) depend on datatype!
The 'decimate array' is a nice way to get the single values from your MUX array - but it is of limited help when your requirements change that often. Make your own subvi to DeMUX your data! (This will be a good exercise to learn LabView Smiley Happy)
Message Edited by GerdW on 05-29-2007 09:47 AM
(3,679 Views)
