run once inside timed loop
I have a timed loop that monitors equipment. Whenever there is a fault I have it send a notification email. My problem is how to stop it from sending email every single time the time loop is executed. I tried placing the send email inside a for loop but quickly realized that the entire loop itself is reiterted. Any help is much appreiciated.
Message 1 of 17
(5,034 Views)
Hi icemaker
I'm not really sure what you mean. Wouldn't a case structure be a solution?
case structure
Could you post some code so we can see what you are doing?
Best Regards
David
NISW
Message Edited by Davidek on 10-02-2009 09:58 AM
Message Edited by Davidek on 10-02-2009 10:00 AM
Message 2 of 17
(5,029 Views)
This is very similar another enquiry today...
One possibility: Add a boolean shift register to your loop, initialised outside the loop. When an error occurs and you send your message, set the boolean to a value that means you've sent your message. Your "send a message" should avoid sending a message if the flag says you've already sent one.
You may also want some means to reset the flag so you can send mesages again. Maybe make the shift register hold the time you last sent an error message, so you can send another one after a certain time has elapsed.
Just a thought.....
Rod
Message 3 of 17
(5,021 Views)
Ahh, now I get it. Just one email per error, good morning Smiley Very Happy
Rod's suggestion is very good, you should give it a try.
Best Regards
David
Message 4 of 17
(5,017 Views)
I am going to give Rod's suggestion a try. In the meantime here is a snippet of my loop. Still new to labview so any suggestions are greatly appreiciated.code.png
Message 5 of 17
(4,995 Views)
In your ap, what good is a For Loop that runs once?
Richard
Message 6 of 17
(4,986 Views)
That was an attempt at solving my problem of non stop emails but I soon realized that would not do anything.
Message 7 of 17
(4,983 Views)
Have you fixed your non-stop emails yet? You screen cap doesn't have the solution (shift register).
Richard
Message 8 of 17
(4,980 Views)
Accepted by icemaker
You might also consider using  the First Call? primitive under the sychronization pallette.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 9 of 17
(4,976 Views)
Looks like the first call will work for me.
Message 10 of 17
(4,974 Views)
