Not able to connect a cluster of control ref to the Register for Events node
Hi all,
I have to check for value change of a clusters containing control refnums. For this I connect this cluster of controls refnums to the Register Events node. But it will not allow me to do so for certain clusters. I have attached 2 such clusters. Perhaps I might be missing something obvious..Any help will be greatly appreciated.
Priyadarsini
(3,004 Views)
You can only connect a reference itself to the event registration node.
Do you want to check for every of the referenced controls?
To that you can use the following code construct:
Ton
Ton
Message Edited by TCPlomp on 14-10-2009 03:24 PM
My LabVIEW Ideas
(2,998 Views)
I would like to make clear that the cluster has refnums of different data type and also some strict and some non-strict. So it is not possible to wire that to Cluster to Array node. But I think that this is not a problem because there are some other similar clusters which could be connected to the Register for Events node without any error.
(2,973 Views)
Are you sure? What do you really want to do?
I think the register for event structure expects an event refnum. Try "Create user envent".
(2,967 Views)
ok in addition to the user events I have to wire the refnums of certain controls to check for their value change in some other VIs. For this purpose I group similar controls refnum as clusters and wire them. It was working fine for most of the clusters but the 2 which I have attached earlier. Now attached is the cluster which will wire properly to the Register for Events node.
(2,965 Views)
