resgister for event on multiple boolean refs
Thanks for the idea Kyle, but your suggestion adds some extra work to the other work-around : simply adding a numeric control ref in the cluster, it doesn't create any problem and lets me use the event structure in a "normal" way.
Epictetus
Antoine Chalons
Message 11 of 15
(1,204 Views)
Accepted by topic author TiTou
Hi!
Thank you @Kyle97330 for your explanation how to use the array version of the dynamic event registration.
I just tested the demo VI with LabVIEW 2016 and there is no error in connecting two latched booleans to the value change registration (see attached VI snippet). LabVIEW 2015 SP1 still gave me the error.
So in my opinion this is an error that is already fixed and there is a workaround for older versions that Kyle97330 thankfully explained nicely.
Any questions left open?
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
Message 12 of 15
(1,174 Views)
Nope, thanks for the wrap-up.
Epictetus
Antoine Chalons
Message 13 of 15
(1,153 Views)
@TiTou wrote:
Steve,
Shouldn't it work whatever the mechanical action? I think it should.
And :
1 switch : ok
1 latch : ok
1 switch & 1 latch : ok
2 switch & 1 latch : not ok
2 switch & 2 latch : not ok
2 switch & 2 latch & 1 num : ok
 The logic seems to be on the Last element, it's not allowed to be latch. Do the 2016 release notes mention it?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 15
(1,140 Views)
The error in connecting two latched booleans to the value change registration still exists in LabVIEW 2020 (see attachment). The above mentioned work around (wiring a non-boolean to the last cluster elements) still works.
Message 15 of 15
(424 Views)
