required in labview project
hello sir/madam,
I am working on labview project.i am learning myself and implementing the logic.
I had a doubt.does using merge function will effect ohter signal.suppose i am merging two signals using merge function.so will one signal effect other signal after merging.waiting for your positive reply
(2,579 Views)
Hello
You're giving very little details about what type of signal you want to merge, can you please explain a bit more so we can try to give you a helpful answer?
If you could post the code (VIs) that can show what you mean by "merging signals" it would help a lot.
Epictetus
Antoine Chalons
(2,575 Views)
I assume that the OP is talking about the "Merge Signals" from the express palette.
If so, no, it is not harmful; the signals will NOT have issues like cross-talking or whatsoever.
Norbert
Norbert
Expert: Geometry
(2,557 Views)
hello,
First of all thank you for your response.i have cleared my doubt about merging any number of signals and displaying it on waveform chart.
I have other doubt.So there are two signals.As one have 8 value and other has 10 value.i have merged this two signals using merge functions.now at output of merge signal is a single wire.From that single wire i have extracted one signal by specifying channel number.say that signal value is 8.i have done subtraction operation on that single.now this subtracted signal i have merged with already merged signals.so my question is now value 8 should be overriden bt this subtracted value and on chart it should show subtracted value and value 10 which is not operated.bt i am getting three graphs.one is value with 8 ,other with value 10 and other with subtracted value.bt i dont value value 8 on graph instead i need subtracted value and value 10 on graph.i even have attached the code .pls suggest me the solutions.
waiting for your response.
(2,552 Views)
