graph x-axis data which is not time
How do I make a grpah in labview in which the X-Axis is my collected data and not time?
Gil Maor
(3,618 Views)
Have you looked at the XY Graph? Please provide at least a few details on what you are trying to do and the problems you are having.
(3,601 Views)
@Gil_Maor wrote:
How do I make a graph in labview in which the X-Axis is my collected data and not time?
Simply change the axis label to whatever you want. 😄
(If the x-values are equally spaced, you can cantinue using a waveform graph. Set the offset and multipler according to the linear relation between x value and array index. If they are not spaced evenly, use an xy graph.)
(3,585 Views)
Try this,
                   Do the customization according to you.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,573 Views)
Solved the issue, thanks
(3,553 Views)
