remote panel control
Hi
Does anyone know if there is a way to control an applicaton via internet
in local machine under the subnet (192.168.0.2)?
(3,209 Views)
Absolutely. This has been around since the beginning of LabVIEW 6i (the "i" stands for Internet, i.e. Internet control/communication.)
Do a search for remote control of application on NIs website, and also look in the examples that ship with LabVIEW and you should be able to find everything you need.
(3,209 Views)
Quick note,
I believe IP' startiing with "192" are not routed.
Control and monitoring will only work on the same LAN as the target machine.
Ben
(3,209 Views)
