read only number from string and number
I have "COM4" from my I/O.  how could to read number 4 only?
  Thank you
Message 1 of 11
(19,107 Views)
There are many ways to do this. The string palette has several string search functions, such as Match Pattern. The LabVIEW Help for this function explains how to use it to find various things, such as just numbers. Hint: Look at the "A sequence of one or more digits" line.
Message 2 of 11
(19,098 Views)
scan from string COM%d but there are many ways depending on the string assumptions (regular expressions, string parsing, match string) ....
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 11
(19,097 Views)
On the I/O I selected "COM4" but I only want to see only number 4 on indicator, please give me more help detail.
Message 4 of 11
(19,087 Views)
I think a regex pattern of [1-9]+ should work in this case.
What kind of indicator?
Message 5 of 11
(19,076 Views)
Accepted by stevevantran
Like the attached image you can try it in "n" number of ways
Guru (CLA)
Message 6 of 11
(19,056 Views)
How about using the resources you already have? Try this. Open LabVIEW>>Click Help>>Find Examples>>Select the search tab and type in "strings" and you should find "Extract numbers.vi"
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 7 of 11
(19,019 Views)
Hello, i might need your help regarding this matter.
I'm current taking a reading from Arduino from 2 accerolmeter to Labview. X=0.02 Y=-0.03 Z=0.99 A=0.33 B=0.42 C=0.84 (Example)
But when i display them using Waveform Chart in labview, I need to use the array to count the position of the String from buffer which sometimes might be inaccurate due to the the value extracted.
I was told that i can use Search string from the beginning to allow the waveform to take in only the numeric.
Are you able to assist me regarding this issue?
Below attached are the pictures..
Message 8 of 11
(14,899 Views)
Jim
Message 9 of 11
(14,870 Views)
I realize a new question was asked, and jcarmody did a great job of answering it.  But I remember seeing a regular expression which pulls out a number from a string, and I've used it to turn a text file into a 2D array of numbers by splitting and processing each row.  It isn't as fast, but it is more robust because it works with any number in a string decimal or not, and the format of the string isn't needed for the processing.
http://forums.ni.com/t5/LabVIEW/regex-find-number-at-end-of-string/m-p/2511362#M764254
The regular expression is this.
(\d+(\.\d+)?)(?!.*\d+(\.\d+)?)
Message 10 of 11
(14,849 Views)
