Help doing an spectral analysis
Hi, I am doing a research study at university using Arduino Uno, LabVIEW and an accelerometer à352C33.
The idea is to attach the accelerometer to a structure and with a hammer make the structure vibrate and then make that signal analysis with a power spectrum in order to know the natural frequencies. I have some questions:
  1. - The accelerometer needs at least 18V but with 5V the signal measuring is good for what I need but the spectral analysis is not. Does this have something to do or even with 5 Volts is should show some values?
  2. - I have 2 options for measuring and both don’t show correct values for the spectral analysis (with the Fourier Transform). 1à Use a point by point filter and the Fourier for point by point. 2à Use a for loop to keep some values and create an array and then use a normal filter and Fourier to evaluate the signal.
I upload 2 Vi and some captures to show you that none of those solution works and I am stuck at this point. I am happy with the signal measuring cause is sufficiently precise but I can’t get the natural frequencies.
Any suggestion will help. Thanks in advance
(3,301 Views)
No one can help?
(3,268 Views)
What is wrong with the spectral analysis?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,256 Views)
None of my Vis show a proper espectral análisis and dont know if it is the arduino problem or my program problem
(3,246 Views)
What results do you see in the Loop Rate (Hz) indicators?
The last time I looked at the LINX Analog Read VI it was only capable of reading at 20-40 Hz.  That means that your analysis of freqeuncies would only be valid up to half that frequency (and then only if you had no aliasing). Every hammer/accelerometer system I have seen generates frequencies into the kHz range or higher.
The Nyquist criterion cannot be ignored just because it is inconvenient for your hardware.
Lynn
(3,212 Views)
