"relative" real time
My mistake, consider this post as non existing Smiley Tongue
Message 21 of 32
(1,669 Views)
Hi Tim,
Thanks again for taking a crack at this.
The previous code you posted wasn't giving me the correct values. I looked at the new code and didn't see exactly what i was looking for I don't think.
The RPM from my program I get correctly.
maybe i'm not being clear but i'll try again:
If I am sampling at 10000 HZ and taking 3000 samples then in 0.3 seconds of data I could have 2 and sometimes 3, 5-volt spikes.  I am able to pull the RPM out of this already from my program.
I would like to calculate future position, i.e. the next 2 spikes based on the last two spikes RPM and position.  I would like I think some sort of counter that either counts how many milliseconds it takes to get from one peak to the next.  If I have that then I believe I can predict the future position of the shaft pretty accurately.
Let me know if I'm still unclear or not getting something...
(As of now purchasing new hardware is not an option)
Message 22 of 32
(1,651 Views)
correction - i would like that counter to work in "real time. (really past time but count)"  i.e. not just tell me the differecne (period) but tell me how the input signal varies with time.  This i believe will give me a pretty accurate indication of future angle in at ANY given time.
Message 23 of 32
(1,649 Views)
Just count the amount of samples and multiply by 100µs (1/10kHz).
But that is complete nonsens!!
Why try to calculate the future position??
To do something at two different angular positions like you suggested in the other post??
You said it yourself, in one acquisition you get 2 or 3 spikes, read 2 or 3 rotations of the shaft, and now you ask for a way to do something in between two spikes, read during 1 rotation?
Those positions you look for are long gone by the end of the acquisition!!
You need a triggerd acquisition system so that your software can act the moment one pulse comes in.
Even then it will be hard to calculate/estimate the position of the shaft since both systems, hardware = the shaft vs. software = your code, has complete different, non synchronized timings.
In this or the other thread (can't remember) you talked about a windtunnel (hugh, expensive stuff bla bla bla), is there really no way two add one more switch so that your software can be triggered by those switches.
You also never answered my question about digital acquisition instead of analog Smiley Sad
Message 24 of 32
(1,642 Views)
i tried counting number of samples and then multiplying by 1/10khz but it wouldn't count.
From what i'm understanding my setup sucks and i need to improve it.
i'm new to labview and data acquisition (as you can tell) so i don't really understand what i benefit by taking an analog signal and converting it through software to a digital signal.
I was looking at the analog example you showed me.  Where do I go from there once I setup the data acquisition?  I guess I need help writing this program from scratch then because I don't understand.
Message 25 of 32
(1,634 Views)
Consider the array of 3000 samples.
First rising edge is at location 683.
Second rising edge is at location 2475
So time between the two edges is (2475 - 683) * 100µs = 0.1792 sec = 5.5807 rpm
That wasn't so hard, right?
You don't have to convert anything!
The signal from the switch is or 0V or 5V right?
Then that can be seen by a digital I/O pin as "0" and "1" respectively.
So you can use that signal as a digital input signal.
If by "swith" you really mean a switch, then you should use a pull up or pull down resistor to ensure both levels.
I mean, you can't leave the digital I/O pin "free". It has to be or 0V or 5V never floating.
Check with the MAX if the hardware detect the levels correctly.
Once you got that right start with the triggered digital acquisition.
Just take 1 sample with a sample rate of e.g. 10kHz
The hardware will check the rising edge of the switch for you at high speed.
The software will do nothing while waiting for a trigger from the hardware.
Don't forget that at 1000rpm you have only 60msec in between 2 pulses.
So if your code takes more than 60msec to execute things will go wrong Smiley Surprised
Message 26 of 32
(1,616 Views)
Yes, I can calculate the time between rising edges too.  As I said earlier I want to know between rising edges what is happening and you said i can't do do that if my code is taking too long.
I'll try and look at the digital setup you are suggesting
Message 27 of 32
(1,614 Views)
Somehow I have the impression you want a high speed version of this:
http://www.ladyada.net/make/spokepov/index.html
Greetings from Germany
Henrik
LV since v3.1
Message 28 of 32
(1,608 Views)
Uum, i'm not sure what you sent me.  I don't really know how to be any clearer of my goals then what I have stated already.
The end all result needs to be the following:
At a certain shaft degree say 20 degrees, a trigger needs to go off which will start a VI, and at say 30 degrees a trigger will go off to end a VI.  This is why I wanted to find the position of the shaft.
Message 29 of 32
(1,604 Views)
Those 20° and 30° are, I suppose, after the trigger from the switch, right?
Suppose speed is 1000rpm, then 360° = 60msec, 1° = 0.16666msec
Trigger switch is time 0, 20° is at t= 3.3333msec and 30° is at t= 5 msec
You want to run a VI for only 1.666 msec Smiley Mad
What is that VI doing for 1.666msec?
This is definetly not a task for a PC!
This is a task for a stand alone µC like this one for example.
Message 30 of 32
(1,601 Views)
