"*" and "numbers" patterns
Hello, world
I need help with creating a LabVIEW VI.  Input a number for the Rows, Display 3 strings.
An input control
A stop button
3 string indicators.
Message 1 of 13
(3,359 Views)
Hi Jason,
An input control
A stop button
When you need those controls: you will find them in the controls palette when editing the frontpanel!
Once you got the "number for rows" you just need a loop to run as many iterations as the user requested…
Which help do you need?
You should know this forum is not intended to provide homework for free. When you have a problem with your VI you should attach your VI and point to the specific problem you have with this VI!
(When you attach VIs then I would prefer them to be saved for LV2017.)
Message 2 of 13
(3,322 Views)
I need to create a VI look like this.
This is my back panel. I'm struggling with how to make the pattern like the pic above.
please help me!
Message 3 of 13
(3,290 Views)
Hi Jason,
no need to start a new thread for the very same problem.
Mind to attach your VI? (Please provide it for LV2017 or older, when you want more help from me.)
Message 4 of 13
(3,279 Views)
This is what I'm done so far. I know I need a case structure, a while loop.
For filling inside, I don't which commends will output the string pattern.
I'm using 2019 labview
Message 5 of 13
(3,274 Views)
When you are asked for a previous version of LabVIEW you can use Save for Previous and choose the version.
Message 6 of 13
(3,258 Views)
Hi Jason,
I guess you were able to solve your homework by now after you had about 20 hours of spare time.
Hint:
The code behind the front panel not even needs the full size of that window.
And you don't need a case structure, just one loop…
Message 7 of 13
(3,240 Views)
Could you please show me the back panel? I feel I'm getting there but I'm really struggling with this problem.
I'm doing the number of rows is input.
Message 8 of 13
(3,230 Views)
You are using LabVIEW 2020 and still failed to follow the directions to save for a previous version. Many users on this forum do not upgrade to the latest LabVIEW versions for various reasons.
Message 9 of 13
(3,225 Views)
Would you tell me what commends are they under the front panel?
I really appreciate your help!
Message 10 of 13
(3,169 Views)
