Alternative of "Refnum to path" in LabVIEW NXG?
Is there any alternative function of "Refnum to path" in LabVIEW NXG? I can't seem to find one. I just hope to do something like the original LabVIEW function of:
Thanks!
(1,896 Views)
Accepted by topic author pji
Hi pji,
As far as I know, there's no way to do this using the functions from the palette. It is possible to roll your own version by creating a Shared Library Interface, and setting the path to LabVIEW. You can then call the function FRefNumToPath. When creating the SLI, make sure to check the UTF-8 option for paths containing Unicode. An example SLI and project is attached.
(1,831 Views)
It works well. Thanks a lot!
(1,797 Views)
