"Scan From String" - something I didn't know...
Hey, everyone.  I noticed fairly recently (I don't know, maybe a couple of years ago?) that, not only can you control the representation of a number by wiring a constant to the "other side" of the output, but you can also give the wire a name!
When did you find out?  I feel kinda dumb.
Bill
CLD
(Mid-Level minion.)
Message 1 of 25
(3,659 Views)
It makes sense.  But I didn't know it either.
Message 2 of 25
(3,617 Views)
I've known the data type trick for a very long time.  I never tried naming the constant though.  It makes sense and this gives me ideas for making it easier to debug that node.
Message 3 of 25
(3,581 Views)
Since we are having fun with the Scan From String, did you know you can define a Boolean and an Enum with a string or a numeric?
Message 4 of 25
(3,576 Views)
I'm like Crossrulz -- I knew about wiring Inputs to get specific types of Outputs, but didn't know about naming the constants (though I've used Named Constants in other situations where I've needed to "name a constant" -- I don't remember the exact use now, after the Stupor Bowl).  However, Bill's example is peculiar -- in order to get the Indicator wired to the output of Scan from String to take on the "name" of the Input Constant, you need to bring the output wire into a Frame Sequence (or maybe any other structure).  Crossrulz' example illustrates this -- notice an input constant named "Enum String", while the output is named "Enum Strnig".
Here's Bill's example using a Case Structure instead of a Frame, and showing both types out Created Indicators:
Interesting.  There are undoubtedly other "features" to be discovered ...
Message 5 of 25
(3,564 Views)
Hmmm, if you create an indicator directly from the output, you get "output 1" as the indicator label, but the wire is named "Test Value 1".  But if the wire goes through a tunnel and you create the indicator from that, the label of the indicator takes the name of the wire...
Bill
CLD
(Mid-Level minion.)
Message 6 of 25
(3,559 Views)
Wow!
Bill
CLD
(Mid-Level minion.)
Message 7 of 25
(3,557 Views)
This whole topic came about because I saw a recent topic about "Format Into String" and it reminded me of "Scan From String".
Bill
CLD
(Mid-Level minion.)
Message 8 of 25
(3,555 Views)
The "Scan from String" (and the converse) enum as a string is something we use extensively in our software. It's a great feature.
Message 9 of 25
(3,537 Views)
Bill,
From Mark Twain, something like: "If a little knowledge is a dangerous thing, who has enough to be out of danger?"
This is an interesting topic, BTW.
Message 10 of 25
(3,476 Views)
