"Find Resources" does not work after Application Builder Installer
I use Lv Full 6.1 / Appl.Builder 6.1
VISA:"Find Resources" acts properly as long as a built application is installed on a PC that has LV installed.
as soon as only the runtime eng. is installed no resources are found.
Who helps?
(2,584 Views)
VISA is NOT installed as part of a LabVIEW built application. You can choose to include the VISA run-time engine or the full VISA install but you have to use the Advanced option on the Installer Settings tab and Run executable after installation. LabVIEW 7.0 makes this all easier.
(2,584 Views)
Thank you Dennis for your reply. I tried to install the VISA runtime engine via the "Run executable after installation" but it appears to run the Visa-runtime-engine-installer before ending the application installation. So I had to run that installer manually. Nevertheless you pushed me in the right direction.
THANKS
(2,584 Views)
