Arrays
Dear all,
I have the following problem: I have an array with some floating numbers. I want to check if the array contains two or more times a same value. In that case I want to delete the double values so that the array contains every value just one time. Can somebody give me some example code on this? Thanx in advance.
(3,107 Views)
The OpenG toolkit has just what you may be looking for. See http://openg.org/tiki/tiki-index.php?page=OpenG+Toolkit%3A+Array
(3,107 Views)
If what you mean is to remove all duplicates then there is a good implementation of it included in the array part of the openG toolkit which you can download at http://prdownloads.sourceforge.net/opengtoolkit/array-6.0.1.1.zip?download
The toolkit has lots of other useful functions though so you might want to download the whole kit, in that case it's:
http://prdownloads.sourceforge.net/opengtoolkit/all_packages_ogtk-1.1.zip?download
Mads
(3,107 Views)
Thanks a lot
(3,107 Views)
Thanks a lot
(3,107 Views)
