question on stacked sequence
I have a question regarding stacked sequence.
I have a stacked sequence with 5 sequences (0,....,4). I would like to execute these in this form
0, 1, 2, 1, 3, 1, 4, 1  then again 0,..
I don't want to duplicate the 1 section since it contains many objets, variables,...One possibility would be to move out the objects then duplicate the sequence and use shift registers but I don't want to use this because in 1, I have some real time graphs to plot..
Is there another (easy) way to do this ?
Thanks for ideas,
(3,676 Views)
Accepted by topic author nitad54448
Why use a stacked sequence?  What you want is a state machine something like thisSmiley Wink
(3,673 Views)
A state machine would work if state 1 knows where to go next.
Another answer is to use a FOR loop with a CASE structure inside.
You have a constant array structure, with  0, 1, 2, 1, 3, 1, 4, 1  in it, and the FOR loop autoindexes that array to get a single number and executes that case.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,661 Views)
Sequences MUST execute in order until all frames are complete, and there is no escape. Don't use stacked sequences, they are too limiting.
You don't need to duplicate it. Create a simple state machine with cases 0,2,3,4 and add the code of state 1 right after the case, so it executes at each iteration of the loop after any of the states.
Here's a quick draft (LV 8.0) that would cycle through the states as you specified forever. See if it can give you some ideas.
Please show us your actual code, maybe we have a few better suggestions.
(3,649 Views)
hi
thanks for the "state machine" suggestion. I just hoped there is a way to make sequences execute more than once (intercalate some, for instance). I can't see nor put the code now (I am at home, no LV here) but got the ideea.
thanks again,
(3,647 Views)
