python or mssql in labview
Can I write everything in LABVIEW instead of python or SQL?
for example.
the python code
conn = _mssql.connect(server='****',
database= 'mydatabase')
can that be translated to LABVIEW?
Krispiekream
(3,378 Views)
I'm not a python user, but it looks like you're opening a connection to a database there.  You can do that in LabVIEW using the Database Connectivity Toolkit or some ADO drivers that Mike Porter posted here: http://forums.ni.com/t5/LabVIEW/Extracting-one-column-from-Database/m-p/544341/highlight/true#M25632...
(3,360 Views)
Accepted by krispiekream
This is what it looks like with the Database Connectivity toolkit.
I use connectionstrings.com to get the connection strings for various data sources.
Jim
(3,335 Views)
