Microphone Voltage RMS
I am using a Bruel and Kjaer 4994B microphone to record sound levels with with a cDAQ-9174 and a PCB Piezotronics signal conditioner. I don't have the sound and vibrations add-on to help me with this.
I want to use the data recorded by the microphone and convert it into decibels and other sound level readings.
To do this I believe that I need to convert the output voltage into a RMS voltage.
I try to acquire voltage RMS from the microphone but LABVIEW returns an error message.
If anybody could help me with this it would be much appreciated
Message 1 of 15
(6,975 Views)
Adding the code and the Error number/message  REALLY helps 😉
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 15
(6,971 Views)
I agree with Henrik_Volkers, it is too little information...
Message 3 of 15
(6,965 Views)
Yeah, sorry, that would be useful.
Attached is the VI, it is very simple at the moment. I was planning to do decibel calculations in excel, a way to do it in LABVIEW to read to a file would be useful though if you had any tips.
The error returned when running the VI is:
Error -200431 occurred at DAQmx Create Channel (AI-Voltage-RMS).vi:4330001
Possible reason(s):
 Selected physical channel does not support the measurement type required by the virtual channel you are creating.
 Create a channel of a measurement type that is supported by the physical channel, or select a physical channel that supports the measurement type.
 Property: AI.MeasType
Requested Value: Voltage RMS
You Can Select: Current, Resistance, Strain Gage, Temperature:Built-in Sensor, Temperature:RTD, Temperature:Thermistor, Temperature:Thermocouple, Voltage, More:Voltage:Custom with Excitation
 Task Name: _unnamedTask<1>
Message 4 of 15
(6,960 Views)
Try to change AI Voltage RMS to AI Voltage in a DAQmx Create Channel.
Simyfren
Message 5 of 15
(6,952 Views)
I did this originally and I do acquire the signal, however when trying to calculate decibels a RMS voltage/pressure is required. This is because the output of the microphone oscillates above and below 0v as expected, but the calculation for decibel uses log10 of the value. Therefore the input has to be a positive value.
I would like to get the VI to run as a continuous sound level meter.
Message 6 of 15
(6,948 Views)
And what DAQ (physical) do you use?
Simyfren
Message 7 of 15
(6,940 Views)
I have:
NI cDAQ-9174 CompactDAQ
B&K 4944B microphone
PCB Piezotronics Signal Conditioner 482C
Is this the information you require?
Message 8 of 15
(6,937 Views)
Yes, its strange that you cannot use Voltage RMS...
Simyfren
Message 9 of 15
(6,929 Views)
I agree, but I am new to LABVIEW so I could be omitting something simple
T
Message 10 of 15
(6,927 Views)
