programmatically export selected area of table to string array
i am able to programmatically select an area of a table using property nodes selsize and selstart however once i have the area selected i cant seem to export the data to a string array. tried value property node. just returns all the data, not the data i am interested in. help much appreciated.
(2,808 Views)
Accepted by topic author eword
Hi eword,
you can use "Array Subset" to get the part you need.
Mike
(2,801 Views)
yep. your right. thanks 🙂
(2,797 Views)
