program runs once correctly, then fails
Suspect that some array or file is open when program is finished running and returns to main menu.
First run of program always works well, subsequent runs fail.
Must restart program completely to run another test.
Have searched for undefined arrays, and unclosed files.
What else should I look for?
How can I reinitialize program without completely restarting the program?
Message 1 of 26
(4,078 Views)
Do you open references to anything? Do you start any I/O with devices?
Cory K
Message 2 of 26
(4,070 Views)
You could at least tell us in what way it "fails". (crash, incorrect results, inoperable, etc.). That probably could give some clues.
What does the program do?
Do you have any uninitialzed shift registers or feedback nodes?
Do you have any partially wired output tunnels set to "use default if unwired"?
Do you close anything that needs to be kept open (DAQ task, file, etc.)
Message 3 of 26
(4,066 Views)
Details of failure = test runs, but rather than gather 30 data points and end, it gathers one data point then ends.
Message 4 of 26
(4,054 Views)
What about my other three question?
Message 5 of 26
(4,038 Views)
Are you using some Control/Indicators to store values? They will be kept in memory.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 26
(4,018 Views)
can you post your code? Or image of portion of the code in which you are facing problem.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 7 of 26
(4,014 Views)
1  Do you have any uninitialzed shift registers or feedback nodes?
2  Do you have any partially wired output tunnels set to "use default if unwired"?
3  Do you close anything that needs to be kept open (DAQ task, file, etc.)
1  Found one unitialized shift register, was simply a choce between gallons per minute or gallons per hour.
2  Yes I have many of these partially wired output tunnels set to "use default if unwired".
3  I do not beleive that I have anything that needs to be kept open.
Message 8 of 26
(3,981 Views)
The control you are using to track the sample count is not being reset* either when the program stops or before it starts to do it work.
Ben
* I admit this is a wild guess based on mostly nothing.
Message 9 of 26
(3,975 Views)
I am using the iteration terminal of a WHILE loop to count samples.
Message 10 of 26
(3,963 Views)
