problem with html saving
Hello everybody
I try to print in a html file my diagram block, but after follow all the steps of the print menu when I push the save bottom I recieve the following message:
Failure saving file xxxx.html!
I think that this problem can be because the block diagram is big and the program can´t generate the pictures but I´m not sure.
Thanks for your time
(2,817 Views)
It's working here with LV 7.1.1 and Windows XP and a very big block diagram.
Can you post your vi, I'll check if it woks too.
Paulo
(2,811 Views)
I have printed the html pages. The problem was that I use LV7.0 and W98. I change it to LV7.1 an WXP and now I can print.
Goobye
(2,792 Views)
